Packing Densty
Packing Densty
Is there a table or formula available to calculate the relative packing density of spherical particles based on the particle size? (i.e. What is the density of a cubic foot of lead shot in the various shot sizes?)
RE: Packing Densty
1) Establish a reference volume (you chose 1 foot3)
Vref = 1 foot3 = 0.028 m3
2) Calculate the volume of a unit cell of the spheres with radius r
Vunit = (2√2r)3
3) Calculate the actual volume of spheres
Vsphere = 0.74 Vunit
4) Calculate mass of spheres
msphere = ρmat Vsphere
where ρmat = mass density of sphere material
5) Calculate reference density
ρref = msphere ÷ Vref
Cory
RE: Packing Densty
I did have some information on the apparent density of iron, steel, and lead shot of the same size, big point. I'll look for it. It was for working with radiation shielding.
I've seen articles on the apparent packing density of iron and lead shot in gun and reloading magazines.
RE: Packing Densty
Are you talking about a mixture of different sizes, or just one size?
Is the size of the sphere significant in comparison with the size of the container?
Is elasticity important?
The direct answer to your initial query is that the packing density is invariant with the size of the sphere in the simplest case.
Cheers
Greg Locock
RE: Packing Densty
The spheres are commercial lead shot, the application is ballasting a boat. The shot is poured randomly into the keel and bilge area, then stabilized with polyester resin.
Several years ago I weighed 2.5 quarts of the stuff we had on hand at the time, and calculated a density of 440 pounds per cubic foot.
Having seen some other published numbers for the density of generic lead shot, I'd like to be able to do a reality check on the various numbers to see which are likely to be the most correct.
(For anybody out there who needs to ballast something, check out the copper jacketed bullet scrap from ammo manufacturers. It weighs in at 400 pounds per cu ft.)
RE: Packing Densty
RE: Packing Densty
The worst is 5.5% but I have no idea how they define that!
http://mathworld.wolfram.com/SpherePacking.html for more references than you can shake a stick at.
Cheers
Greg Locock
RE: Packing Densty
Mathworld: wow
(Thanks for the link)
Steven Fahey, CET
"Simplicate, and add more lightness" - Bill Stout
