SW 2004 hole table origin datum
I have a 9.5 x 9.5 plate w/ 2.25 corner radius.  I am trying to use the new hole table for the first time but cannot get past the placement of the origin datum to get my x/y coordinates.  there isn't really anything to snap it to...no temp. origin or endpoint.  i guess i could sketch a line to snap to it's endpoint but i'd have to delete it and then what would happen to my datum? how do you fix a datum? help doesn't really explain what you can attatch it to. please help me, i'm working on this drawing right now. thanks.
RE: SW 2004 hole table origin datum
Use Virtual Sharps. See help files.
Set the type of VS you want under Tools > Options > Document Properties > Virtual Sharps then when in the drawing, hold down the Control key & select the two lines which you want to have your VS linked to, then release the Control key. Next select the Point icon in the sketch menu & your VS should appear. Now when you insert your Hole Table you have something to select as your Origin.
NOTE! If you select the * or + as your VS it may appear extremely tiny on the drawing, but it will be there.
from (the City of) Barrie, Ontario.
Everyone has a photographic memory. Some just don't have film.
