AWS D1.1 welding Code
The AWS D1.1 welding code is talking of the "Rule of Eight". Does anybody knows what it is all about?
Thanks.
Thanks.
RE: AWS D1.1 welding Code
Code Rules, in 8 sections, are as follows:
1. General Requirements
2. Design of Welded Connections
3. Prequalification of WPSs
4. Qualification
5. Fabrication
6. Inspection
7. Studwelding
8. Strengthening and Repairing Existing StructuresAlso,
AWS DI .l/D1 .I M:2002 18th Edition abstract states:
This code covers the welding requirements for any type of welded structure made from the commonly used carbon and low alloy constructional steels. Sections 1 through 8 constitute a body of rules for the regulation of welding in steel construction.
There are twelve mandatory and twelve non-mandatory annexes in this code. A Commentary of the code is included with
the document.
Dave
