Warehouse Heating Load Help
How would one determine the heating load for a warehouse where all that needs to be heated is the area near the ceiling to 45-50F. All they want to do is keep the pipes from freezeing. How should I determine the heating load for such a case?
Any help would be appreciated.
Thanks!
Thanks!
RE: Warehouse Heating Load Help
Much cheaper initial cost and energy costy.
You could probably reduce the amount of heat you put into the space by looking at what percentage of the space you are heating (only the top half, or third).
Eng-Tips.com : Solving your problems before you get them.
