circular waveguide mode suppression
Hi
I have a circular waveguide which can propagate both TE11 and TM01 modes due to its diameter. I would like to be able to suppress the TM01. Are there any easy classical ways of doing this? I cannot make the waveguide any smaller by the way...
thanks
thanks
RE: circular waveguide mode suppression
Brute force mode filters short out the E-field, orthoganal to the desired mode E-field. others can use lossy materal parallel.
My initial guess, I have none of the reference materials at hand, But TM01 has a circular E-field, bessel functioned.
Insert a printed circuit, low ER, with thin printed copper circles, that correspond to the peak of J01 function.
If neccessary, l/4 matching can be incorporated to lower the TE insertion loss.
However, the mode I have (which I'm pretty sure is TM01) has a radial e-field pattern, not circular.
I'll try & track down the MIT radiation labs titles again...
thanks
