IGES into Catia from Solidworks 2004 SP 3.0
Has anyone tried to IGES out a SW prt with datum planes into Catia V4? How do the datums come across?
RE: IGES into Catia from Solidworks 2004 SP 3.0
I believe IGES is capable of handling datum plane and axis entities.  However, SW is not set up to import or export them.
You might try making planar surfaces to mark key planes if needed.
