MERCURY REMOVAL SYS
MERCURY REMOVAL SYS
Dear All,
we are currently in need of your support for providing for an executive project a mercury removal system from a water stream where:
a) mercury is the only heavy metal , with a inlet concentration of maximum 5 ppm
b) water flowrate is 5 m3 / hr
c) the desired outlet mercury concentration is 5 ppb
d) the water comes from a preliminary oil removal system with CPI and flotation unit
we thought about a precipitation system with a polymeric agent or similar, we would like your kind support in understanding if a more complicated system would be required such as resins, with all related utilities etc. or a precipitation method would be enough. The water then passes to a biological treatment, so I would like to understand if 5 mg / lt of mercury could poison the biological cycle. We are concerned about COD content in case we use resins first, on the other hand.
thank you in advance for your cooperation !!
Andy
Andy
RE: MERCURY REMOVAL SYS
Do you have a complete analysis of your wastewater stream besides heavy metals. For example, do you have results for the following tests:
(1) pH
(2) Conductivity
(3) TSS
(4) BOD
(5) COD
(6) Nitrogen/Nitrates
(7) Surfactants
(8) Oil & Grease
What is the source of your wastewater? Type of plant/facility you operate?
Todd
www.oxilume.com
oil 500 ppm with density 500 / 900
BOD 2500
COD 5000
SS 100
ph between 6,5 and 9
conductivity no value
mercury 5 ppm max
some amine (MDEA) coming form CO2 removal plant
the plant name is oily water treatment plant, downstream processes in a gas plant
thnak you in advance!!
Thanks. I'll get back to you tomorrow.
Todd
www.oxilume.com
i do hope you could assist me in this hot stuff. some more info are:
so the main point is the mercury, which has to be removed by 1 K factor. Main points, very urgent now are:
We thought about CPI + precipitation + Activated sludge + resins. Does it sound?
I am in need of references of actual plants, as our chance now is given by this reply to the client.
How can a competitor of us let this water with this high COD content pass in the resins first? Or maybe he lets pass mercury in activated sludge as mrcury at this level does not affect the biological cycle?
H-E-L-P !!!
i am also reachable at andredd@yahoo.com
