Leaf spring design
4
Leaf spring design
Leaf spring design
Can anyone help with pointing me in the right direction for design calculation of leaf spring capable of taking loads of 1000kg to 3000kg - For use on slow moving vehicules
Jan
RE: Leaf spring design
MANUAL ON DESIGN AND APPLICATION OF LEAF SPRINGD - SAE HS J788 FOURTH EDITION 1982. There maybe a newer one.
That would be a great place to start. It is also fairly easy to design them from scratch, using a spreadsheet and classic beam theory.
However, to get you going, here is the formula for a multileaf spring, from the Bosch Blue Book
Bending stress= 3*length*Force/(width*N*thickness^2)
N is the number of leaves in the middle, n is the number at the end
rate=(2+n/N)*E*N*width*thickness^3/(6*length^3)
This leaf spring is triangular in side view, ie each leaf is a fixed amount shorter than the one above.
The Devil is definitely in the details, which is where the SAE  book will help.
Cheers
Greg Locock
Hi Greg,
I have had a go at the formula you have shown. Just a few questions ….
If length, width and thickness is in m, Force in Newton’s. N is the number of leaves at the end. i.e. next to the eye … With 8 springs and 2 at the end (1 is the top spring with the eye) The other 6 are then evenly shorter …right ??
The calculated rate is then the movement in m (from the centre of the spring) for each N applied to the spring ??
E = Youngs Modulus for the material used.
Or have I got myself barking up the wrong tree here ….
Appreciate you comments on this …
Jan
N=8 n=2, everything else you say is correct.
Cheers
Greg Locock
Hi Creg
Thanks for your reply. I think I must have a decimal error. With ….
L = 0.89m
F = 24516N
W = 0.05m
N = 8
n = 2
t = 0.04m
E = 210000 MN/m^2
The rate is 2.86m … clearly not right ….??  I must have missed something ….
Jan
Maybe t = 0.004m?
Norm
And I think that the formula assumes a symmetrical spring package with the axle located at the midpoint as seen in side view and defines the length "L" as being from the axle to either eye rather than being the overall length of the spring between the eyes.
Norm
Yes, L is perversely the half length of the spring.
I don't see how you got 2.86, I think you've got an arithmetic error.
I'd use a t of more like .015, and more leaves, for this design.
You probably want 400-2000 N/mm (roughly) as a rate
Cheers
Greg Locock
It looks like I am using to many “0” in my value for E …. The error with the thickness did not help matters ! Thanks for point out that L is ½ the physical length of the spring
Jan
Can you please explain why I can only get a sensible answer when I use 210x10^6 for E. I thought E should have been 210x10^11 (in Newtons)
Jan
Hi claver
E for steel should be 210*10^9 N/m^2 or 210*10^9 N/m^2.
regards desertfox
