Importing bmp into Wildfire
Adding object (bmp) seems to work ... somewhat. As, the colors are right but the problem I have is the object is always a square!
I have to "stretch" it into shape. Seems to satisfy the artwork drawing requirement; if you know the shape/size in advance. I draw the die cut as a curve in part and add artwork in drawing.
Any ideas!
Any ideas!
RE: Importing bmp into Wildfire
