Pump efficiency prediction
The similarity rules for centrifugal pumps dictate that homologous operating points of a certain pumps (changing velocity) have same efficiency. Starting at BEP of a pump runing, say, 1750 rpm (max. efficiency = 80%), the similarity rules predict that there must be an homologous operating point at lower velocity, say, 1500 rpm with the same max. efficiency = 80%. But practice indicates that at lower velocity the max. efficiency is also lower, then 80% eff. is no possible al 1500 rpm. Theory fails?
RE: Pump efficiency prediction
the similarity laws assume constant efficiency which is clearly incorrect but normally acceptable for small changes in operating variables.
Cheers
Steve
Thank you very much for your reply. I found that theory is aprox. OK for flow rates larger and lower than BEP. At BEP same efficiency is inconsistent.
