assy-sketch-Can I break associativity of offset-sketch, from it's part
I have a sketch on an assembly, that is an offset of a surface of a part in the assembly.  I want to fix the sketch, where it is and not have it be able to change as the associated part changes.  There's a lot of entities to it. Is there a way to break this associativity rather than pick each entitiy, and delete the offset entity relation? I'm using 2003.
RE: assy-sketch-Can I break associativity of offset-sketch, from it's part
In your sketch tools toolbar, click the "Display/Delete Re;ations" button (or menu picks "Tools --> Relations --> Display/Delete...") to see your constraints.  In the drop-down list at the top, select "External".
From this menu, you can view and delete all of the offset constraints.
Due to illness, the part of The Tick will be played by... The Tick.
http://www.EsoxRepublic.com
