Section lines on separate sheet...
Does anyone know how to have section lines on a separate sheet to the corresponding section view?
Thanks in advance
Jeff
Thanks in advance
Jeff
RE: Section lines on separate sheet...
(Just for my future reference).
NbLYLYDdy
Anyway, the solution is the same...
To put the section arrows on a parent view, when you want the actual section view on another sheet, you need to create the section view on one sheet, select the view you want the section arrows on. Then, move the section view to the other sheet (switch sheet).
But, he may have been talking about something else all together.
1. Create the section view.
2. Right mouse button over the new view and choose add section arrows
3. Change to the sheet with the view you want the arrows on. Choose the view you want the arrows on.
I think that's it as I'm typing this from memory.
Jeff
