problem with axes
problem with axes
problem with axes
In the following example i am creating a figure and adding an axes to it. i want to do a quiver plot on the created axes. for this i am setting current axes to the created axes. But when i am calling quiver it is being plotted on a automatically created axes. please let me know what could be the problem.
h_figure = figure('Units','characters',...
    'Position',[49.8000   13.4615  120.0000   35.0000],...
    'Color',get(0,'DefaultUicontrolBackgroundColor'),...
    'HandleVisibility','callback');
h_axes = axes('Units','characters',...
    'Position',[10 4.5 72 26],...
    'Parent',h_figure,...
    'XLim',[-100,100],...
    'YLim',[-100,100]);
strFilename = 'FOT024-03_FOT030-01_Jan_04';
% init file parameter
nHeaderLines = 12;
% open file channel
[fid,strMessage] = fopen(strFilename,'r');
% error handling
if fid < 1
    disp(strMessage)
    return
end
% loop over lines
iLine = 0;
iData = 0;
WNo = 0;
while ~feof(fid)
    strLine=fgetl(fid);
    iLine = iLine + 1;
    % continue reading header
    if iLine <= nHeaderLines, continue,  end
    % break if empty line
    if isempty(deblank(strLine))
%       break
        if ~exist('data'), break, end
        WNo = WNo+1;
        TD(1,WNo)={data};
        iLine = 1;
        nHeaderLines = 9;
        iData = 0;
        clear data;
        continue,
    end
    % data section
    iData = iData + 1;
    %example data line
    %M0 2    1     7.833   -7.770   0.0113  -0.0163  PASS
    % converting data line to numeric datatypes
    try,
        data(iData,1:6) = sscanf(strLine,'%*s %d %d %g %g %g %g %*s')';
    catch,
        break,
    end
end
lineSpec=['-r';'-b']
for i=1:length(TD)
    data = cell2mat(TD(i));
    Wy=data(:,1);
    Wy=data(:,2);
    Gx=data(:,1)*26;
    Gy=data(:,2)*32;
    Sx=data(:,3);
    Sy=data(:,4);
    Dx=data(:,5);
    Dy=data(:,6);
    axes(h_axes)
%     hold on;
    quiver((Gx+Sx),(Gy+Sy),Dx,Dy,lineSpec(i,:))
end
fclose(fid);
RE: problem with axes
Hi kollurulp.
This might sound silly - and sorry if you've tried this already, but it looks like you have commented out the "hold on" command.  Another thing you could try is replacing the semi colon after it with a comma, or removing it altogether.
Char
