rubber testing
rubber testing
All the standards talk of testing the hardness (in case of rubber) on test specimens. Is there a way to check the hardness on the very small irregular parts (not specimens)? The requirement is on Shore A scale.
RE: rubber testing
If the readings you need are more for your information, an irregular shape should give a close reading. If you're using the info to report, you should make a flat witness panel from which to get your readings.
