Gridded Systems
Gridded Systems
Gridded Systems
In an grid system 2-1/2" and 1-1/4" can I use pipe saddles instead of  2-1/2x2-1/2x1-1/4" tees?.
RE: Gridded Systems
Of course...no reason to use the tees.  Unless you have money to burn.  If you are using steel piping, it would be cheaper to have the fabricator weld outlets onto the main.  This is common practice and leads to a lower installation cost overall.
