MacroFeature screen redraw
Hello everyone...
I give up... I’ve tried everything is possible... I was making a macro feature that creates a retaining ring groove… So I create a temporary cylinder with the same diameter of the shaft, other with the internal diameter of the grove, then I subtract the last from the first and finally I subtract the resulted body from the shaft main body and there should be my feature… well… it is there, I just can’t see… if I pass the mouse pointer over the feature the new feature’s faces and edges are highlighted, but I have to do a forced rebuild to see it. If I delete the feature the same happens, the display won’t update. As I’m new with macro features I tried to do another one to be sure I didn’t do any big mistake. Now my the macrofeature makes keyways, I have a shaft, then I make 2 temporary cylinders and a box between them, I made an union operation with them and to finish I subtract the resulted body from the main shaft body. Same problem… the feature is there but the model don’t update. But with this one not even the force rebuild works, I have to close the model and then reopen, this is the only way to see the keyway in the shaft. Here is the part of the code that creates the bodies and make the operations:
Function swmMain(swApp, swModel, swFeature)
Dim swModeler As SldWorks.Modeler
Set swModeler = swApp.GetModeler
If sType = swExternalType Then
' RASGO EXTERNO
Dim sStartCyl As SldWorks.body2
Set sStartCyl = swModeler.CreateBodyFromCyl(cylDimArray)
Dim sMidBox As SldWorks.body2
Set sMidBox = swModeler.CreateBodyFromBox(boxDimArray)
iMacroFeatureData.GetEntitiesNeedUserId sMidBox, IdFaces, IdEdges
cylDimArray(0) = KeywayEnd(0)
cylDimArray(1) = KeywayEnd(1)
cylDimArray(2) = KeywayEnd(2)
Dim sEndCyl As SldWorks.body2
Set sEndCyl = swModeler.CreateBodyFromCyl(cylDimArray)
ResultBodies = sStartCyl.Operations2(SWBODYADD, sMidBox, errorCode)
ResultBodies = sEndCyl.Operations2(SWBODYADD, ResultBodies(0), errorCode)
Else
‘ not implemented yet
End If
Dim Body As Variant
Body = swModel.GetBodies2(swAllBodies, False)
Set swPartBody = Body(0)
If Not swPartBody Is Nothing Then
Dim resultBodiesPerm As Variant
resultBodiesPerm = swPartBody.Operations2(SWBODYCUT, ResultBodies(0), errorCode)
End If
End Function
Please, any help will be appreciated since there’s no reference about this part of the API in the web, at least I couldn’t find, and the help is very crap explaining these concepts :o(
Best regards,
Rodrigo Basniak
SolidWorks Mechanical and Piping Designer
A1 Engenharia e Gerenciamento Ltda
' RASGO EXTERNO
Else
End If
Dim Body As Variant
End If
End Function
Best regards,
Rodrigo Basniak
