pcmk/a to plc2/16
pcmk/a to plc2/16
pcmk/a to plc2/16
I'm having a problem with getting a pcmk/a card to work with a plc2/16.
I followed the technote about modifying the config.sys file with no luck so far. I have tried the list of memory ranges listed by AB
Any help would be appriciated
RE: pcmk/a to plc2/16
I once had a problem in which the card would not communicate to any of my compatible devices.  It took a registry edit to clean out the old entries so the new correct ones could load.  This was on Windows NT.
Maybe there is a related tech. note in your case?
