PG-35 - Opening in Flat Heads
PG-35 seems to be dealing with flat heads with a SINGLE opening. What about flat heads with MULTIPLE openings?
Should I calculate an equivalent single opening with the same surface area as the multiple opening areas added up together?
Thank you for the help.
Antoine.
Antoine.
RE: PG-35 - Opening in Flat Heads
But any suggestion/tip/idea is still welcome.
Thanks.
Antoine.
