tool holder with oscillating for turning
Sirs
I am looking for any information abut Tool Holder for turnning that use oscillating or high vibration to halp
the cutting opration'
the tool holder can be for carbide or HSS cutting tips.
if any one heard abut a tool like this please give any information
thanks Katz
thanks Katz
RE: tool holder with oscillating for turning
I believe that much other work has been done on fast tool servo's and you may find what you are looking for if you search along these lines.
www.cranfieldprecision.com
Rich
cavitie's drilled and filled for loose carbide bit's to soak
up the chatter. This does not alway's work. the best way is
to have the entire bar made from chatter free metal.
there is a company called mac-tech in rochester MI, that
design's special cutter's. try them.
Incase you want a tungsten alloy boring bar can be supplied from India at very low cost contact happ@tr.dot.net.in
vksingh
The actual internal methods are a little more complex than a few holes filled with carbide, they are self tuning oil filled tubes basically
