In-wall, low voltage wiring requirements
Is it necessary to use UL listed wiring when installing low voltage wiring (CAT5, Coax, speaker, etc.) in the walls of a home under construction? Can I just use the less expensive variety that is not UL listed?
RE: In-wall, low voltage wiring requirements
See Article 100, 110, 110-3b. Approved for the purpose means acceptable to The Authority Having Jurisdiction.
Its your license!
Christopher Caserta
Sr. Regulatory Engineer
ccaserta@enorthhampton.com
Ph:904-225-0360
Fax:904-225-0340
