boolean question
boolean question
boolean question
Hi everyone,
I'm trying to do boolean operations (subtract and/or intersect) using parts in the 'assembly mode' but the combine feature dosen't work. I notice that the combine feature specifies "two or more SOLID bodies". Are the parts I import into assembly mode not solid? Is there a way to make them solid? I know how to do boolean in 'parts mode' but I'd like to take advantage of the mating conditions and ease of moevment of parts available in the 'assembly mode'. Any suggestions on how to do this?  I can do this in pro/d by importing a part and then making one or more of the parts "solid", before proceeding with the boolean operations.
Any help is appreciated,
TIA
Carlo
RE: boolean question
Look in SW help index for "in-context features" and "joined parts".  That should get you on the proper path.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thanks for your reply, MadMango
I looked into your suggestions but it appears that in the assembly mode parts can only be joined , not subrtacted or intersected. Any other suggestions for boolean operations in assembly mode? I've tried saving the part as an STL. file hoping that this would make it a solid but I can't open such a file.
Carlo
Use join to get the bodies into a part file, then use combine to perform the boolean operations on the resulting bodies in that part file.
One peculiarity about join I recently experienced in SW 2003:
If I selected multiple bodies from multiple components in a single join operation, the bodies remained separate.  If each join feature had one single part, the resulting bodies of subsequent joins were automatically merged with the body of the first join.
Due to illness, the part of The Tick will be played by... The Tick.
http://www.EsoxRepublic.com
