Elictrical panel boards fabrication
Hello
We have a big project,that will need many panel boards.We are planning to build our fabrication plant.Could you advice what are the main machinary,equipment and tools required for this plant.
Thank you
Thank you
RE: Elictrical panel boards fabrication
US or EU or Asia or Africa or South pole... your location will allready make some difference, try to find your (other)local requirements and standards the equipment must comply with. How big is big ??, to determinate the equipment (panels)you need a lot more detailed info is required, basicaly we would need an overall requirement to give you at least an idea of what you would need.
kind regards,
Danny
1. Sheet metal cutters
2. Bending machines
3. Welding robots
4. Drilling machines
5. Grinding machines/tools
6. Torches
7. Punch presses
8. Circular saws for metals
9. Polishing machines
10. Etc.
The proposed panels will be in the range of(100-3000A)Main circuit breakers 420 volts,50 hz low voltage power system.
Good luck!
further more what we inted to do is a fabrication unit noe a factory that .This fabrication unit will be a steel fabrication unit plus an assembly unit and wiring for the panels.
Any way thank you so much for your encouragement.
I'm involved deeply in ArTu system of ABB (up to 4000A, Icw=105kA, IP65, Form 4), so further I can give you some support. Try to contact local ABB organization.
In brief, use tested structures and just make assembling in your country
Please don't get disturbed by the response of jghrist. He was trying to help you. As you must be aware that all panels are according to some standard e.g. BS, DIN / VDE, IEC, IEEE or JiS etc. For qualification, some type tests are essential on proto types which is a costly affair. I think the suggestion of vtakev is worth considering for the above reason.
God bless.
mta2003
