Dew Point Calculations
What would be dew point for air as well as Natural gas, each having Water content: 14 lb/MMscf @85 deg F & 110 psig?
How it is calculated?
RE: Dew Point Calculations
I recommend starting the last question in a new thread with a title associated with the question.
rmw
Look at API 510. Section 5.4.2 deal with sizing a flare KO drum.
Best regards
Morten
Possible methods of scrubbing a low volume, low conc (20-250ppm)VOC(isopropyl alcohol) stream, and their advantages/disadvantages. Already searched for possible ways to scrub VOC's but could find no design info, basically want to demonstrate that it is not economically feasible to scrub these emissions.
Ways of scrubbing acid vapours (HF, HCl, HNO3 mix)and alkaline vapours(ammonia, caustic) other than using packed columns. Especially any info on dry scrubbing techniques. Again, want to justify the use of wetted packed columns to perform the scrubbing operation as opposed to other techniques.
Any information is much appreciated.
Cheers
Shaun.
