Why it doesnt work?
Why it doesnt work?
Why it doesnt work?
why this code doesnt work?? if i put k += 1 it gives the correct anwer k = 6
*Whats going on?
 Sub Main()
Dim m As Double(,) = {{6, 2, 6}, {1, 3, 7}}
Dim k As Double
Dim  A0 As Double
Do Until A0 = 1.0
            k += 0.1
            A0 = m(0, 0) / k
        Loop
        Console.WriteLine("k is " & k)
RE: Why it doesnt work?
Try defining the value of array as follows
Dim m As Double(,) = {{6.0, 2.0, 6.0}, {1.0, 3.0, 7.0}}
1) In VBA += is not a valid operator.
2) The exit condition for loops should never depend on comparing floating point numbers. Due to how the computer stores numbers you may end up with A0=1.0000000001; which does not equal 1.0 and the loop would keep going.
It looks like you want to normalize an array. In this case k=1/A0, no need to loop to find the value of k.
