Can anybody highlight on dimensions of dishedend as per admerkblatter?
Normally I am connected with inspection &review of design as per ASME code .Recently I am doing design review of pressure vessel as per AD merkblatter where certain formula is given for finding out crown radius & knuckle radius of dished ends.If manufacturer wants to deviate from dimensions achieved as per above (i.e. mfr wants to adopt dimensions as achieved in as per ASME) Shall I accept above dimensions ?
RE: Can anybody highlight on dimensions of dishedend as per admerkblatter?
If a vessel is to be in accordance with ADMkBl, it has to be fully compliant with it.
Otherwise, to give an example, how will you check for heat treatment requirements or for skirt length?
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
If your vessel is installed in Germany, your local TÜV will be involved in the approval of the vessel. Having worked with TÜV in the past, I am confident that TÜV will not allow this deviation.
AD-Merblatt B 3, Domed Ends Subject to Internal or External Pressure, and B 4, Dished Heads, contain very straight forward design information. I don’t think that there is anything in these two sections that deviate significantly from Section VIII, Div. 1.
K. Phan
See www.gowelding.com for the latest information on this directive.
ASME VIII div-1.
