Setting Boots With Laser
I need to set boots/hikeups on rough grade lathes prior to undercutting for removal, replacement and compaction of a building pad. Other than setting the lenker rod to the proposed grade I'm confused about how to set the rod for the hikeups. Any suggestions on the best procedure?
