rubber+metal flat gaskets
The gasket of this query consists of a metalic flat ring, say 2mm thick, fully surrounded by EPDM rubber in order to get a finnal thickness of 8mm. These kind of gasket, from what I know so far, are only fabricated in Germany.
Does anyone know some gasket manufacturer in USA that can quote the above described ring gasket?
Thanks in advance
