Points of emission on P&IDs
Is it a standard practice to show all possible points of emission (threaded connections like vents and drains or break flanges) on Piping and Instrument Diagrams? Is this only for hazardous fluids/gases? Has OSHA dictated that these be shown? Thanks for any insight!
RE: Points of emission on P&IDs
All valves should be shown IMO to accurately depict the system. Flanges are not typically shown except at vessel connectons (and then not always) and/or where you have a spectacle blind in the system or something like that. Basically, flanges shown are the exception.
Hope this helps.
saxon
--Mike--
However, different companies have different P&ID standards...
I personally believe that a P&ID should show every valve that gives the operator access to the process, but should not attempt to be a piping drawing. If you must keep track of every connection and joint which might become a point of emission in a piping system, your only recourse is to keep a set of accurate as-built pipe routing and isometric drawings. A 2-D P&ID cannot do a decent job of representing that information anyway, without losing its ability to fulfill its core functions.
This is our method to comply with EPA requirements. The valves are tagged in the field with a unique number and that tag number is also on the P&I-D. This makes it more convenient to locate the actual valve in the field.
ben
