Help With Associative Dimensions
I'm updating autocad 10 files to autocad 14. Wow, what an upgrade right? Is there a way to convert the non-associative dimentions to associative dims?? I'm tired of deleting all the dims and re-dimentioning them all.
RE: Help With Associative Dimensions
you can make as if you wanted to change a text inside the drawings, and use the program for this:
www.ononinc.com
www.homescript.com
as drawings open in batch and are saved again,
they are saved in the later version from which you start this batch operation.
