importing step files using Ideas version 8 m2 and xp
I learn how to do this with iges files but now I would like to know how to import step files using Ideas version 8 m2 and xp
For iges file you type in /xto co bo fc im
This does not work for step files however
RE: importing step files using Ideas version 8 m2 and xp
There is no equivalent command to get the STEP translator working.
Orbix may not be working due to incorrect OS. If you aren't running on W2K then you need to be.
