Formulas for sizing a weld
What would be the proper formulas to use for sizing a weld that would hold a branch connection. The main line is 10" schedule 40 with approximately 120psi air in it. We want to branch off with a 3" line. I know everyone is going to say use a weldolet, and that is more than likely the way we are going to go. It will be a 90 degree branch.
But, I am a rookie engineer and I am interested in seeing some formulas and sizing a weld or welds.
Thank you for your help.
UncleSam
UncleSam
RE: Formulas for sizing a weld
For welds other than piping get access to the "Design of Weldments by Omer Blodgett" there is a section (6.3) for determining weld size for various types of connections.
The book can usually be purchased from any bookstore or directly from the website..
https://ssl.lincolnelectric.com/lincoln/spmount/item.asp?prodnum=DW
