life expectancy of steel casing pipe
We are doing a jack and bore in Phoenix, Arizona.  City of Phoenix is concerned about the life expectancy of 48" Steel Casing Pipe.  We are thinking of using the casing pipe as a storm drain.  The City is requesting a life expectancy of 75 years.  Field resistivity of the soil is 4711 (ohm/cm).  Will a 1/2" thick casing pipe be thick enough?
