Using "OR" in an "IF" statement
Im trying to perform an action depending on the selected cell. Only a number of cells are valid so I want to test if the cell is one of a number of valid cells.
My trial macro goes like this
Public Sub selec()
Row = Application.ActiveCell.Row
col = Application.ActiveCell.Column
testselection = Row & col
If testselection = 44 Or 46 Then
MsgBox ("right selection")
Else
MsgBox ("wrong selection")
End If
End Sub
For some reason the answer is always "right selection" no matter if I select one of the two cells.
Can anyone advice on this or is there another way of testing?
Thanks, Mogens
Public Sub selec()
Else
End If
End Sub
Thanks, Mogens
RE: Using "OR" in an "IF" statement
if testselection=44 Or testselection=46 then...
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
Its only that I have about 250 numbers (cell adresses) to check.
Is there a shorter code to test this?
Mogens
I think you should write the addresses of your cells in a named area, then use one of the lookup functions to check if any given cell is there. This will make your code reasonably flexible and modifiable.
prex
You feed the range in your code by identifying it and looping through it.
Suppose you have your values in column A
sub dothejob()
dim columnA as range
set columnA=activesheet.columns("a:a")
'which makes the code accesss all values in column A
for each cell in columnA
'insert the code for selec() here
next cell
end sub
Improvement of the code for efficiency is left for your excercise boss
regs
IJR
