Plugging of valve due to sulphur dust
We encountered a problem recently in one of our metering station where the valve is plugged up. When the valve was disassembled, the sulphur dust have somehow collected on the drilled-hole cage. The gas stream is heated upstream and no plugging occurs in the piping until it reaches the valve.
Is anyone aware of this problem? is there some chemical phenomenon similar to hydrate formation that occurs with sulphur?
RE: Plugging of valve due to sulphur dust
