Partner With Us!
(Download This Button Today!)
Member Feedback
"...This was the ONLY place that I could find information that I could use to resolve the problem. So thanks once again to member TomSark and the SQL forum!..."
Our company interested in developing wet coatings processes. Our coatings are single layer, 4-10 microns in thickness (wet) and our product specs dictate that we can not use spin coating or any of the vacuum coating techniques. That limits the choice to slot type coaters, roll coaters, or rod (such as Meyer rod) coaters. These coatings will be done on glass: upto 400x400mm sheets. The liquids are shear thinning with zero shear viscosity around 5 Poise. Also, these coatings are for optical applications in the LCD industry. So, require very high precision equipment and the manufacturing will be done in a clean room. The last requirement might not be a must during the process dev phase. Currently we are in prototyping phase of the process equipment and have quite a few prototypes. But we can use help from some experts in the field who already have a feel for different coatings techniques, so we don't end up re-inventing the wheel. What would also be most helpful is if this expertise comes from a company which has prototype/lab scale coatings equipment where we can try different coatings approaches.
I would appreciate any recommendations on where to go for expertise (preferably and/)or process development facility.
English is not my first language, this is a translation from "Babelfish"....
Hello, I is about to transfer this technology to windowpanes for Caravan's and living mobile. The job takes place via syringes, rollers or pouring. The order quantity amounts to approx. 20-30 gram/square meters. The result is a glass layer in 5-10 Micron thickness; If you are interested in German technique - wet lacquers -, let me know please.
Start A New Thread
DESCRIPTION: Chemical coatings engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
