Cutting Sections
Cutting Sections
Is it possible to cut a section through surfaces?
Paul.
Paul.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Cutting Sections
To Section a surface in a part you will have to add a surface that cuts through the part like you want it. Then do a trim. Then hide the new surface.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
In the drawing, you can hide the surface bodies in the view you want to show just the section.
