Creating AutoCAD DXF file by VB
Hi !!!!
Can anyone please tell me how to create AutoCAd compatible DXF files from Visual Basic
(sorry ...it might be a many time discussed old problem)
Shakildor
Shakildor
RE: Creating AutoCAD DXF file by VB
DXFText = 0 & vbCrLf
DXFText = DXFText & "SECTION" & vbCrLf
DXFText = DXFText & 2 & vbCrLf
DXFText = DXFText & "ENTITIES" & vbCrLf
The last four lines are always:
DXFText = DXFText & 0 & vbCrLf
DXFText = DXFText & "ENDSEC" & vbCrLf
DXFText = DXFText & "EOF" & vbCrLf
When DXFText is complete, create a text file and print to it like:
Open "C:\" & FileName.Text & ".Dxf" For Output As #1
Print #1, DXFText
Close #1
You need to know the group codes for AutoCAD. For instance, to do a circle, it's:
DXFText = DXFText & "CIRCLE" & vbCrLf
DXFText = DXFText & 8 & vbCrLf
DXFText = DXFText & Layer$ & vbCrLf
DXFText = DXFText & 10 & vbCrLf
DXFText = DXFText & Round(CenterX, 4) & vbCrLf
DXFText = DXFText & 20 & vbCrLf
DXFText = DXFText & Round(CenterY, 4) & vbCrLf
DXFText = DXFText & 40 & vbCrLf
DXFText = DXFText & Round(Radius, 4) & vbCrLf
In this case, 8 preceeds the layer name, 10 preceeds the x coordinate of the circle's center, 20 preceeds the y coordinate of the circle's center and 40 preceeds the circle's redius.
Each AutoCAD entity has similar "codes" that identify it's geometric description. Find them in AutoCAD help or a book. YOu can also lear a lot by creating a dxf file in AutoCAD and reading it.
Here is where I found out the DXF syntax.
http://usa.autodesk.com/adsk/servlet/item?id=752569&siteID=123112
I made functions for simple tasks, such as WriteCircle(Dim radius as Double, Dim x as Double, Dim y as Double, Dim layer as String) etc.
-Matt
A similar approach can be used with PHP on a web site so you can take user input and send them a dxf drawing.
