Timber species and grade
Are there any reliable methods to determine the species and grade of existing timber construction without having any design documents available? Non-destructive testing?
I was not able to find any information stamped on any of the members.
RE: Timber species and grade
Thread337-90860
I don't know of any non-distructive test that will tell you the species of the wood, but there are a number of non-distructive tests that do tell you a lot about the condition of the wood.
Most any wood technologist should be able to identify the wood species without destructive testing as long as end grain is accessible. You might try a university extension service. If, as your name seems to indicate, you are in Michigan, you have a couple of the best in the country available.
He will need enough access to see side grain and end grain on the wood. Tools needed are a sharp pocket knife and hand lens.
Grade is almost entirely visual so he should be able to develop this at the same time.
Griffy
