ORGIN KEEPS MOVING
ORGIN KEEPS MOVING
I try to set my orgin at 0,0,0 and it appears to set. But as I go along and if I check my elevations, I have stuff all over the place in reference to Z. What am I doing wrong, cant I set my Z to a point and have it keep it there no matter what view I am in or use? Very frustrating when I try to break a line at a intersection and behold they arent touching.
RE: ORGIN KEEPS MOVING
There is an Express Tool called Flatten... which might be of some assistance.
You can also use the -CHANGE to the Properties dialog box to change the THICKNESS nd/or ELEVATION properties of objects bck to 0 (zero).
Or you could try pasting this into a new button in
"Macro associated with this button".
^C^C_UCS;;_move _all;;0,0,1e99;;_move _all;;0,0,-1e99;;
- Tracy
"Everybody is ignorant, only on different subjects." — Will Rogers
