Contamination of seal oil
hi,
Direct contact of process seal oil inside the centrifugal compressor sealing system, causes the contamination of oil by dissolve of heavy components hydrocarbons ( C7 to C12 ) include in the row gas.
The caracteristics of the used oil are :
Flash point is approxmatively 200° C
Viscosity is 46 Cst
Temperature of degasing crank is ( 75  -  85  °C )
Is s there any other kind of oil synthetic or mineral
with same caracteristics of used oil that the missibility of (C7 to C12 ) can’t happen ?
thanks
