Winch drum & flanges thickness
How do i calculate the thickness of the drum & flanges
on a winch drum ?
Lenght 1,5m , D=1,2m , wiredia=32mm , flangedia=1,8m
linepull=48MT= 480000N
I tried to apply the DNV rules but got a 14cm wallthickness
on the drum.. overkill or not ?
brgds odd from norway
RE: Winch drum & flanges thickness
If you can get access to the "Design of Weldments by Omer Blodgett" the is method for the design of a cable drum in the “Steel Rolls Chapter”.   The example consolidates all the references from Timoshenko and Roark
The book can usually be purchased from any bookstore or directly from the website or it’s representative in Europe.
https://ssl.lincolnelectric.com/lincoln/spmount/item.asp?prodnum=DW
Thanks a lot guys. Down to approx 3mm now,hehe
only size of flanges missing now
brgds
