Customize the OPEN dialog box?
The OPEN dialog box has a list of "shortcuts" on the left side. How can I customize that list of "shortcuts"? I'd like to add some network folders there that I use repededly to the point of absurdity. I know I can create some windows short cuts and add them to my start menu - I've done that. But I'd like to have some of these same ones available within SolidWorks.
Thanks...
RE: Customize the OPEN dialog box?
I've had the same problem, having to navigate through 15 layers of folders all day. First I created shortcuts in the my documents-folder to all the directory's I used often. But eventually I didn;t like it at all. So I've now created a macro that will give me a small window in bottom-right corner of the screen with 5 buttons on it that will open the file-open-dialog in the right directory's. I also created a small program that will write a text file with these shortcuts in it so the shortcuts are easy to modify. Until now everybody including me is very happy with this tool.
Bouke
Could you post it here for all to see? ... If it's not too big.
from (the City of) Barrie, Ontario.
Everyone has a photographic memory. Some just don't have film.
Just another option (although maybe not as nice as Bouke's macro):
Anytime you find yourself browsing to the same folder repeatedly, once you are there you can hit the little down arrow next to the Open button.  There you will get an option to Add to Favorites.  When you need to go there again you can hit the Favorites link on the left side of the dialog and any shortcuts added will be there.
That's what I've done - sort of. I was just looking for a "slicker" way to accomplish the same. Apparently a few others are too. I'm glad I asked the question.
tatej usfilter.com
Hey Guys,
I've tried to remove all the unnessesary data from the macro and I haven't tested it so probably it won't work anymore, But you'll get the picture, also I have created a program to setup the shortcuts (shorts.exe) and this creates a macro with button-label and path in it. If someone wants the full version I could send it to you over email.
Code:
Dim swApp As Object
Dim retval As Integer
Dim pathShortcuts(10) As String
Dim labelShortcuts(10) As String
Dim dummy As Integer
Dim bool As Boolean
Sub Init()
  Set swApp = CreateObject("SldWorks.Application")
      swApp.Visible = True
  LaadShortcuts
End Sub
Sub checkdoc()
  bool = True
      Set ModelDoc = swApp.ActiveDoc
      If ModelDoc Is Nothing Then
          MsgBox ("Geen part geopend")
          bool = False
      End If
End Sub
Sub LaadShortcuts()
  On Error GoTo Error
  Close #1
  Open "C:\winnt\SWShortcuts.txt" For Input As #1
  dummy = 1
  While (dummy < 6)
    Input #1, labelShortcuts(dummy)
    If (Left(labelShortcuts(dummy), 1) <> "/") Then
      Input #1, pathShortcuts(dummy)
      If (Left(pathShortcuts(dummy), 1) <> "/" And labelShortcuts(dummy) <> "/") Then dummy = dummy + 1
    End If
  Wend
  SetShortcuts
  On Error GoTo 0
GoTo skip
Error: shorts
skip:
End Sub
Sub SetShortcuts()
   Shortcut1.Caption = labelShortcuts(1)
   Shortcut2.Caption = labelShortcuts(2)
   Shortcut3.Caption = labelShortcuts(3)
   Shortcut4.Caption = labelShortcuts(4)
   Shortcut5.Caption = labelShortcuts(5)
End Sub
Sub shorts()
   Shell "M:\Solidworks\SW Tools\IMS tools\shorts.exe", vbNormalFocus
   End
End Sub
Private Sub Shortcut1_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
   If (Button = 1) Then
     On Error GoTo Error
     Dim args As String
     If (Mid(pathShortcuts(1), 2, 1) = ":") Then
        args = ""
        retval = swApp.SetCurrentWorkingDirectory(pathShortcuts(1))
        retval = swApp.Command(swFileOpen, args)
     End If
     GoTo skip
   End If
   If (Button = 2) Then
      On Error GoTo Error
         opdracht = "explorer " + pathShortcuts(1)
         Shell opdracht, vbNormalFocus
      End If
      GoTo skip
   End If
Error:    MsgBox ("Deze functie werkt alleen in solidworks 2004")
skip:
   On Error GoTo 0
End Sub
Grtz, Bouke
