Crazy numbers in Actual Work
Hello everybody,
I am trying to change the Actual Work of a task.
As I am typing in 20hours Project fills the field with the value 19,98hours.
Can anybody tell me the solution for this problem? I do not want project to use such crazy numbers. It shall only use numbers without dezimals.
Thank you very much.
Martin.
RE: Crazy numbers in Actual Work
I have had this problem when  I am copying and pasting values from Excel. If this is what you are doing, use the "roundup" function in excel to calculate the values then import the values as integers.
