Drawings with design table...
Hello !
I have a part with 10 parameters and many consigurations in a design parameter table.
I would like to do a drawing for each configuration but with the same views and cotes in each drawings.
I have a probleme to do this because when I active a new confuguration I have to update all the drawings and then, they all become the same...
Could you help me please ?
THANKS
RE: Drawings with design table...
You don't have to update all the views when you change configurations. After you finish a view lock it.
Hi sebastienmenot
When you have created a view in the drawing workbench of your particular configuration, try right clicking on the view and look for "isolate".  This will drop the link between the CATPart and CATDrawing.  But I don't think you can reconnect the drawing with the part - ever!
Jeff
