Intermittent Assembly mate errors
Has anybody experienced this the way I have. Using SW 2003 and 2004. I have had a few assemblies display errors in the mates when there should'nt be an error. I will do a cntrl-Q and the errors sometimes go away. Or I will suppress and unsuppress one of the mates and the error will go away. Occasionally I have a component in an assembly that is fully mated for get that it is mated and get a minus sign in the feature manager. I attempt to drag the part, it doesn't move but also doesn't inform me that the part is fully mated. After I attempt to drag the part, the rebuild icon displays next to the part in the feature tree. When I rebuild, the part is once again fully locked down. Anybody experience anything like this?
RE: Intermittent Assembly mate errors
http://www.EsoxRepublic.com
For some reason this is happened to me too. Sometimes by reversing (or flipping) the mate orientation fixes it. Maybe SW doesn't remember which way was up sometimes.
I've had the same type of configuration problems Thetick mentioned. I've just steered away from having any conflicting mates when everything in the assy is resolved. That way the mates would never interfere with one another.
In one or two more complex assemblies I've found that the only way to update correctly (at least I didn't have found another way) was to close the files and open them again!
I'm on SW2005, SP2.0 which I know isn't the latest. I'm skeptical that a SP will solve my problem due to the fact that this was a problem in SW2003 and SW2004. Any other suggestions to help solve this assembly? The fact that some of the components "appear" to be free to move isn't causing me any headaches at the moment, but Murphy tells me I should be prepared. Or is that the Boy Scouts?
Dave Gowans
I got an SPR for the (-) showing up on fully defined subassemblies. I can't tell you if it got fixed in 2006 or not. I also have the problem that an angle mate will switch back and forth every time I open an assembly. Click on the mate alignment to flip it back and the assembly is fine. Open the file again and it may or may not be flipped the wrong way. I have only had this in SW2005, SP 0 thru SP3.0 so far.
mncad
Could you post the SPR # so I can check it online?
Dave Gowans
mncad
