Requirement for the PE exam?
Hey all,
Are there certain exceptions to the requirements for taking the PE exam? I read somewhere that you necessarily do not have to have four years of experience. The person in question will have 3.75 years of experience at the time of the exam.
Where would this information be found?
RE: Requirement for the PE exam?
Good Luck
This is spelled out in no uncertain terms on the app. instructions.
Also, when did you do this? In PA, if you "Received degree before June 30, 1994, or who began your experience before February 19, 1991.", you could have the 4 years prior to getting the EIT, whereas those who don't meet the above need 4 years AFTER getting the EIT. But you still need 4 years experience.
The only out I could find: with "NO DEGREE: Must have EIT certificate and the candidate’s amplified record of experience must show at least 12 years of experience (8
of which qualified one to sit for the FE exam) and an additional 4 years gained after the issuance of the EIT certificate, under the supervision of a PE."
A greater percentage of people funk the EIT and the PE exams than flunk the Bar exam! Think about it!
is that university of alabama?? i believe that i am fine with my schooling. auburn will probably get me 4 years of credit.
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
you don't need a PE to be a developer or a contractor - but you may need to have one on your staff... As a developer or contractor, you won't be doing a lot of engineering work, but paying others to do it for you. You might be better of getting a MBA which would help you more run a development business.
If I want to go into Devopment / General Contracting (which, in turn is more money), I really don't need a PE.
So, am I really wasting my time right now doing design work if I really want to be in the development business? I do have a very good background having worked in this field for three years now so I wouldn't lack knowledge.
