Dimension text....
Dimension text....
Does anyone know how to remove or hide the automatic text that is created with a dimension and replace it with a string of text.
Jeff
Jeff
RE: Dimension text....
Using show/erase I don't think you can lose then actual dimension other than by changing its dimcosmetics to the string required, then in the drawing change the D to a S (this shows the symbol).
Created dimensions are easier, change the D to a O and enter the string required.
Is this any help?
Hope this helps.
maybe only a drafter
but the best user at this company!
Jeff
