Welding Symbol/Text color.
I'm working with MDT5 and want to know how to change the welding symbol/text color from the standard yellow which can't be read when printed on white paper.
Sounds simple but I need help.
Nate
RE: Welding Symbol/Text color.
Change the layer color which the symbol resides. Use list to ID layer name.
It is also necessary for the color propery to be set at "bylayer"
Thanks for the advise. I actually already tried that and it worked for part of symbol and later on I found that in edit mode I could select the text, right click and Format Text Color to the same color as the rest. A rather annoying solution but for now it works. What I would really like to do is find where I can change the default settings for color not only for the weld symbols but also for the BOM.
Thanks again!
