What fan motor capacitor size ?
I have a single phase 240v 50Hz Brinsmead condenser fan motor rated at 0.28 Hp, 1.45 full load amps. It is the usual two winding capacitor start/run type motor. What value of capacitance would usually be used with something like this ?
RE: What fan motor capacitor size ?
Startreck:
For a 60 hz 240 volt 1/4 HP it would be 5mfd at 370 volts. I don't know it would be OK at 50hz
Roger
Thank you Roger, I will give it a try.
