how is "wg" defined
how is "wg" defined
how is "wg" defined
I came across the following in a specification:
"...positive internal pressure of + or - 10 inches wg"
1.  What is wg?
2.  How can I measure it?
3.  Can it be correleated to psi or inches Hg?
thanks in advance
chad
RE: how is "wg" defined
Probably water gauge, which you might use to measure the pressure created by a fan, for example. In which case divide by 13.6 to get inches of mercury.
Cheers
Greg Locock
I would confirm Greg Locock's advice that it is inches water gauge IE 10"WG is the pressure that will support a column of water 10 inches high.
If you are in ISO land multiply by 0.248 to get kPa (kilopascals).  IE 10"WG equals 2.48kPa.
